Broken Bolt For Ribbed Belt Tensioner -- NEED ADVICE
Hey Audi Forums
My ribbed belt tensioner was loose so I decided to tightened it and I applied too much pressure and broke the bolt.
#8 is broken
I need advice on how to take the broken bolt out and where can I buy another bolt?
PS.My timing belt kit came with new bolts for the dampner pully and I kept the old bolts. Those bolts look similar dimensionally to the bolts for the ribbed belt tensioner. Can I use the old dampner pully bolts to replace the broken bolt for the ribbed belt tensioner???
#8 is broken
Take the tensioner off (obviously), hit that bolt with some Kroil/Liquid Wrench/PB Blaster/WD40 and use a bolt extractor. I always, always, always recommend Kroil when bolt extractors are used because if you break the extractor, you're screwed.
Or you can replace the whole bracket.
jinsojoo
Oct 30, 2012 11:22 PM
