Bump under seat under acceleration
Old Sep 4, 2013 | 11:47 AM
mattavant's Avatar
Default Bump under seat under acceleration
I've got a 2000 A4 Avant Tiptronic. After it shifts into second gear, there's a bumping under the center console area every time, otherwise it drives smoothly. This happens only in 2nd at a certain rpm. It feels just like I drove over a set of small speed ripples/bumps.
I'm wondering if this is related to the drive shaft. Any ideas would be appreciated. Thanks.
Old Sep 4, 2013 | 04:26 PM
Huskerbob's Avatar
Center shaft carrier bearing would be a good place to start looking. You'll need to remove the heat shield to take a look. 4 little nuts and then work it down. Single exhaust on the 1.8l makes it easy to inspect. Otherwise you may have to drop some pipes. Grab ahold of the center shaft near the center support, carrier bearing, and see how much play you have. You should be able to tell by how much you can move the shaft. You may even be able to reproduce the noise. Strange it only happens in a certain gear but when mine went it wasn't a constant thumping.
Old Sep 4, 2013 | 04:46 PM
mattavant's Avatar
Thank you. I think I'll put it up in the air this weekend and take a look.
Old Sep 5, 2013 | 07:52 AM
mtroxel's Avatar
Mine was exactly like that on my dear departed 96. It was deceleration at a certain speed....20-28 mph. Was one of the cv joints on my drive shaft.
Old Sep 5, 2013 | 07:46 PM
mattavant's Avatar
Interesting. I will look at cv too.
Old Sep 6, 2013 | 08:03 AM
Huskerbob's Avatar
There is a CV joint at each end of the center shaft plus the center support bearing. If you can move the center shaft at either end or in the middle you should be able to make the sound or at least feel it. This whole thing may be a tad over engineered.
ObnoxiousDrunk
May 5, 2009 07:44 PM
redsox12
Jan 29, 2008 04:15 PM
Slowb5
Dec 19, 2005 09:34 PM
rnbguy
Nov 14, 2005 07:32 PM
