squeak.....bump bump bump.
Old Dec 19, 2005 | 01:00 AM
Slowb5's Avatar
Default squeak.....bump bump bump.
OK, so i went playing in the snow and slid into a curb doing 5 mph, now my front right tie area thumps like a flat after 50 mph, and it gets prety bad when i let off the gas. lifted the car up when i got home and inspected everything finding my tire is leaking air. question being....if i fix this tire problem will the bump go away? i pray it will, and i hope it isnt due to a bent rim....but i hit the curb sideways so i dont think its bent...just the tire. and the front right now sweaks, any ideas?
thanks all
Old Dec 19, 2005 | 01:03 AM
Karl's Avatar
Default RE: squeak.....bump bump bump.
could be anything... but more than likely you bent something.. or if you got really lucky you might have just hit had enough to knock the weight off of the rim so its not balanced anymore.. try and get it balanced and see if it helps
Old Dec 19, 2005 | 10:39 AM
Slowb5's Avatar
at 5 mph something bends? i hope not. but yeah, im going to put on the spare and see if the bump goes away. if not, i pray its just the rim.
Old Dec 19, 2005 | 10:51 AM
bhj0887's Avatar
You'ds be suprised how much damage can happen at 5 mph.
But like Red said, try to get the tire balanced first. Or do what you said, put the spare on and see what happens,
Old Dec 19, 2005 | 11:02 AM
Slowb5's Avatar
<----basically what im doing right now.
Old Dec 19, 2005 | 03:13 PM
Grouse's Avatar
LOL it's the not so dead hostage kicking around in your trunk.
Double tap the bastich and then all should be good.
Old Dec 19, 2005 | 09:34 PM
Slowb5's Avatar
GLORY!!! tires plus just rebalanced the rim, and all is well...25 dollars later, she's perfect thus again.
*wipes brow*
redsox12
Jan 29, 2008 04:15 PM
Innie
Jun 18, 2006 03:47 PM
tmorrow24
May 27, 2006 06:23 PM
rnbguy
Nov 14, 2005 07:32 PM
