a/c question
Old Jun 9, 2008 | 09:39 PM
manufan's Avatar
Default a/c question
If a scan reveals that the high pressure switch is open to ground, does that mean without exception that the high pressure switch is faulty? Assuming it's connected.[/align]
Old Jun 10, 2008 | 12:19 AM
Tweaked's Avatar
Default RE: a/c question
No. It could be a bad wire as well. All it means is that the circuit is open somewhere. Break out the DVOM and start doing resistance tests. Or borrow a sensor and see if the fault disappears.
Old Jun 10, 2008 | 08:13 AM
manufan's Avatar
Is there a trouble shooting sequence that I can access somewhere? Is there a relay in the circuit before the switch that could be at fault? The a/c was working fine, then suddenly, no cold air. I checked the wire and connector and see no obvious issues.
Old Jun 10, 2008 | 11:39 PM
Tweaked's Avatar
You'll need a wiring diagram, which I do not have.
You can test the switch with a resistance check or jump the connector and see if the fault disappears.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
