CA and TB time
Old Aug 16, 2010 | 02:29 PM
TeeterTawter's Avatar
^^^I never use protection.
Old Aug 16, 2010 | 04:16 PM
bradtyler02's Avatar
Ditto, nothing better than warm, wet, and sticky...
Old Aug 16, 2010 | 10:29 PM
onepoint8tee's Avatar
My wife yells at me when she has to clean up the mess that is left on door *****, walls, etc. when I don't use protection.
Old Aug 17, 2010 | 09:09 AM
CCA4's Avatar
You might wanna get that looked at
Old Aug 17, 2010 | 11:19 AM
I wipe most of the mess off with shop towels before I go and touch anything outside of the garage...
Yeah, I do it in the garage...!
Old Aug 21, 2010 | 01:07 PM
Alright, on the advice of a certain mod, I'm going to consolidate my rants and raves into one thread, sticking with my original post about mt TB and CAs. I haven't even started on the CAs yet, I'll get to that.
While I had the car all pulled apart, I decided to change my intake mani gasket with the NewSouthPerformance gasket that is supposed to help lower intake temps but about 20*. In the process, I cracked a plastic piece on the back of the head through which coolant flows. Needless to say, my attempt to repair with epoxy and a hose clamp was an epic failure, and after a quick test drive, it leaked, I overheated, and I'm in need of more G12. I found the part on ECStuning, only 20 bucks, no big deal, and not too much of a headache to get back in there and replace it.
All that to get to my real question. Something happens once I hit 10 PSI, the car seems to bog down a little, make some wierd noise, almost like a boost leak, and won't build any more boost. I don't think it's a boost leak though, I only removed one line (DV to intake mani) while doing the TB. It runs fine as long as I keep the boost under 10.
Also, and maybe it's my imagination, but at idle, or coasting, my vacuum is 20 in Mg, and I could have sworn it was closer to 25 in Mg before.
Any input or troubleshooting advice would be great, but naturally, I won't be driving the car until I get my coolant leak fixed. Overall, the TB job wasn't too bad, and one hell of a learning experience. I managed to do the entire job myself without any extra hands, and the blauparts tool kit was rather helpful, but wouldn't have been required if I hadn't done the seals as well. I'm sure I would be able to do the entire process again fairly quickly, and I don't regret doing the work myself at all!
Old Aug 21, 2010 | 01:27 PM
Yeah the coolant flange. Nice! Be extra, extra sure that the new O ring for it lines up perfectly when you install it.
Didnt' you have to remove a couple vac lines on the intake manifold to do the gasket? Sounds to me like you either forgot to reconnect a line on the manifold, or maybe created a leak in one of them in the process. A leak at the intake manifold would explain a drop in vaccum and boost. 20hg is about normal with the AC off, but if you are used to 25hg, then ya.
Old Aug 21, 2010 | 02:03 PM
  #18
I'll take a second look, and if all else fails I'll try the tennis ball trick.
Waxmanronnie
Jul 3, 2014 04:18 PM
rsgore
Oct 9, 2009 09:16 AM
zerinTT
May 20, 2008 09:56 AM
ClemsonKev
Aug 11, 2006 08:06 PM
T and A4
Mar 17, 2005 02:44 PM
