Calling all manual trans/clutch experts...any advice will be helpful
Old Jan 6, 2011 | 03:15 PM
DoctorMemory's Avatar
Originally Posted by FasterA4ThanUrs
I think he just slipped the hell out of his clutch. Probably took a nice chunk of life off it, but not enough to be blown (slipping under normal driving conditions, or at heavy load in top gear)
Sorry, that's what I meant by "glazed". I've seen it a couple times at auto-x events, people slip the clutch a lot and wind up with a coating of friction material on the pressure plate. Then the clutch just slips and grabs randomly. In those cases, if you "granny" it for awhile it all gets knocked/ground off and eventually it's OK. But like I said, I don't think that's what happened here.
Last edited by DoctorMemory; Jan 6, 2011 at 03:16 PM. Reason: Missing "quote" tag.
Old Jan 6, 2011 | 10:37 PM
kevace1's Avatar
However, does the car try to move at all if you are stopped in first with the clutch to the floor?
No, it does not. Im feeling your idea as well, that could be it as well, but i dont get why the same stuttering does not happen when i go in reverse?? should it not?
Old Jan 6, 2011 | 10:43 PM
kevace1's Avatar
Originally Posted by Keegan0103
I bet that leak is your Axle Seal, have you seen a lightweight dark oil recently? I had that seal blow, and lost a lot of fluid (similar smell), and ended up almost running my transaxle empty
where exactly may that be Keegan? something tells me that could be a culprit of some sort, i really need to make sure of that as i plan on changin the oil once i get that triple square socket needed for the manual trans
Does the transaxle or whatever you call the part that i outlined has residual oil on it, share the oil with the manual trans? as it all looks like one unit?
Old Jan 7, 2011 | 12:11 AM
Msnickbroderick's Avatar
Actual WIZARD
As far as I know, no. It was a separate fluid. CV grease is that thick dark almost paste, Manual tranny fluid is a heavier oil, but this should be like valve oil (if you played a brass insturment) or almost like cooking oil, but lighter. I have pics somewhere
Old Jan 7, 2011 | 12:19 AM
Actual WIZARD
Light viscosity, slippery
After 1 hour of sitting
The reason it broke
Old Jan 10, 2011 | 03:05 PM
kevace1's Avatar
hey guys just wanted to update on the situation on my car.....it seems the more accepted reason of me just taking a chunk of life away from my clutch must be it. Because now that i drive my car, the stuttering is pretty much non existent. now the car shifts smoothly. BUT it will shift smooth always if i drop the clutch @ around 1800-2000rpm on first. if it do it how im used to doing it @ around 1100-1300rpms, it will slightly stutter, much less than initially. the car still grabs strong on all circumstances; uphill, on 5th gear @30mph, and even when i start from stop on 2nd. which is still a little mind boggling, but i guess its a good thing. the smell has gone away as well and doesnt come back strong. im assuming its just lingering in te ca because of the rug and cabin filter may, which i just changed like 8k ago, i guess ima have put another one
blackhat
Jan 26, 2011 12:13 AM
jude14601
May 1, 2008 07:14 PM
Agnt008
Feb 15, 2008 07:24 PM
audichicks4
Jan 22, 2008 09:53 AM
smokeU
Jul 24, 2007 11:33 AM
