Cam Tensioner
Old Apr 20, 2016 | 08:35 PM
ProfileTrader's Avatar
Default Cam Tensioner
Hi, I have a 1997 B5 12V (AFC) 2.8 model. I was told there was a Cam Tensioner seal that needed replacing as it was leaking (a mechanic told me upon giving a quote for a TB replacement). I was considering doing this and much more work on the car myself so I was reviewing the DIY section. I am new to this and from what I can see there is no Cam Tensioner seal on this model- I saw it on the 30v (AHA) model. The only cam seals I see are front and back (4). Is this correct.
Thank you
Old Apr 20, 2016 | 08:39 PM
redline380's Avatar
Legal Moderator
Your mechanic probably thinks you have a 30v. There is no cam chain tensioner on a 12v because it is a single cam engine, hence nothing to tension and no tensioner to seal.
Old Apr 20, 2016 | 09:29 PM
thanks for the quick response..appreciated
Old Apr 20, 2016 | 09:46 PM
BTW was I correct in that there are only 4 cam seals.
Old May 4, 2016 | 10:47 PM
ImTheDevil's Avatar
No, it's a single can engine. There is a cam seal behind each sprocket on the front of the engine. Honestly, unless they're leaking visibly, leave them alone. The potential to damage something and create an irreparable oil leak is considerable.
Old Jun 2, 2016 | 02:00 AM
Sorry for the late response Thanks so much for answering. I will check them out and if they look like they are not leaking at all I will leave them alone. I presume the crankshaft seal would be the same protocol.
Are there two 1/2 moon plugs (seals) on the back side of each cam that can be changed. There seems to be oil leaking from the back side and I was told they were cam seals.
Thanks again
Old Jun 2, 2016 | 08:08 PM
ImTheDevil's Avatar
I don't think there are two separate half moon seals but I'm not positive. There may be a similar shaped "dip" in the valve cover gasket though as there is on the 30v. It's very possible that the VC gasket is what's leaking.
Old Jun 3, 2016 | 02:21 PM
Thanks again for your help.
jinsojoo
Oct 30, 2012 11:22 PM
dstrawn
Sep 7, 2010 09:05 PM
Cruz734
Aug 13, 2008 04:02 PM
jcwolfe
Mar 28, 2006 03:56 PM
