Camshaft Adjustment Bank 1 Malfunction - Help would be amazing :/
Hello,
So I VAGed my car back in November? and there was only one error 17927 - Camshaft Adjustment; Bank 1: Malfunction , but car sounded great, etc. so I just cleared all the DTC's , but today I decided to VAG it again and its there again, car runs great ( atleast to me
but there is one issue , when hot it starts weirdly, like when cranking RPM goes up to like 500 drops down then back up finally starting, and it ONLY happens when the engine is hot, so Im guessing it might be related to this issue.
So I checked the Measuring groups and this is what I got https://i.imgur.com/7OND1c0.jpg Apparently 093 group KW should be at 0 for correct position (tbh I dont really know what these numbers mean ) , so I am a bit worried, any help would be appreciated.Could be a timing issue or ? Timing belt was replaced in 222000 KM ,car has 289900 KM now.
Also I took out the connectors on the camshaft position sensor and the tensioner, cleaned them , replugged, cleared DTC , went for a 3km drive and the code is back
Kinda low on the money, so help is much appreciated on figuring out the exact issue.
Thanks.
)but there is one issue , when hot it starts weirdly, like when cranking RPM goes up to like 500 drops down then back up finally starting, and it ONLY happens when the engine is hot, so Im guessing it might be related to this issue.
Kinda low on the money, so help is much appreciated on figuring out the exact issue.Thanks.
pologoped2
Mar 29, 2013 10:14 PM
