Can a bad Airbag Control Module give a CEL?
Old Feb 18, 2009 | 01:20 PM
Munzter's Avatar
Exclamation Can a bad Airbag Control Module give a CEL?
I have a 2000 1.8TQM with ~112000 miles on it. I recently had a check engine light come on, brought it into the mechanic, and they said there were codes for an Airbage control module, bad MAF, bad 02 sensor, and ABS controller. I had them replace the MAF and O2 sensor, and I believe they said the only two remaining codes were for the ABS module and the Airbag control module. I know the ABS module doesn't give a CEL because I've had that code since I bought the car 2 years ago, but can a bad airbag control module give a CEL along with the airbag light?? If not, I will have it scanned at Autozone and post the codes. If this is the cause of the CEL, do any of you have a recommendation for fixing this without having to spend a bunch of money?
pologoped2
Jul 28, 2013 05:47 PM
Silver Bullitt
Jul 2, 2008 08:03 PM
jjuzwik
Dec 10, 2007 12:00 PM
mallett427
Jul 20, 2006 08:06 PM
AndyMelvin
Jul 19, 2005 08:42 AM
