Can't pull codes, how to know which CP?
Old Mar 1, 2013 | 12:51 AM
Frozenguy's Avatar
Default Can't pull codes, how to know which CP?
2000 A4 So I need to drive 400 miles tomorrow.
I can't pull codes and I'm not expecting to find a mechanic that will tomorrow. (does Audi pull for free?)
The other day all of a sudden, a cylinder goes out and the car is shaking like a tank with a flashing CEL. I begin to pull to right lane, give it more power cause it was lacking, the boom it kicks in again and my car accels nicely, CEL gone.
Happened three or four more times on my way to destination. Didn't happen again all day.
Then today it happened but then the light stayed solid but the car drives fine.
Should I just replace cyl #1 CP and then see if that clears the CEL. If not, put old back in, and move new CP to cyl #2, again check to see if CEL is still on?
With that said, how much are they? I don't want to buy 4 in case it is the ICM.
I'm almost certain it's not plugs. It idles fine and drives well but then BAM problem is here, BAM problem is gone.
Old Mar 1, 2013 | 01:38 AM
zandrew's Avatar
Sounds like the **** my car was doing. I swapped to the newer fsi push ins and have not looked back. Car does not miss at all plus better plug gap.
Look and see what cp you actually have. I thought 2000 were 4 pronged. If so you are half way there.
Old Mar 1, 2013 | 12:28 PM
Frozenguy's Avatar
Thanks zandrew, I'll look into that for sure.
As for now, I decided to let her rest this weekend and I got a rental for the trip.
Will tackle it when I get home.
Old Mar 1, 2013 | 02:00 PM
phatjames167's Avatar
you may qualify for the recall on the coils. i don't remember what year they started it, i know my 01 was covered though.
Old Mar 1, 2013 | 07:01 PM
hartsoe1's Avatar
I think only B6 was covered with coil on plug recall. (2001+)
But, you must get your codes read at an auto parts store to remove the mystery.
IronMan111
Nov 23, 2008 12:05 PM
VW01AUDI00
Mar 6, 2007 10:16 PM
nyaudia498
Jan 4, 2007 03:26 PM
hitreason
Feb 25, 2006 12:24 AM
KulS4
Jan 28, 2006 06:50 PM
