can't put fuel in my tank?!
like wth? i suddenly can't put fuel in my tank. the nozzle keeps clicking saying that the tank's full but my meter tells me it's almost empty which is about right for how much i've driven it since i filled it up. tried to fill at more than 1 gas station so i know it's the car. anyone know what could be wrong? dealer said it could be the gravity fuel valve or the bleed valve. either that or the entire tank needs to be changed which.... they want to charge me like 3k for so... if any of you have an idea, let me know please lol. and is the brake light supposed to come on with the abs light when the module goes bad?
Try one more gas station, my girlfriend had the same problem with her 4runner and swore it was the car causing the problem. Took it to the station myself and encountered the same issue, car right? Wrong! Went to the next pump and it worked like magic. You could have just hit the two broken pumps in the area, weird stuff happens.
If it still doesn't work i would say the problem lies in the fuel filler neck, not the tank.
What you can do is remove the hose from the tank, and redirect it to a water bottle or something and start pouring some gas through it. If it doesn't just rush right through it, thats your problem.
Try not putting the nozzle all the way into your filler hole, and don't set the handle at full-open. Mine does this every now and then, I find that by changing the angle of the nozzle aimed into the tank, and slowing it down, the problem goes away.
Here in Oregon, we're not allowed to pump our own gas. The state put out these fancy low emission nozzles that you have to have some PhD to operate I guess.
I'm not complaining though, except when the gas station kid scratches my car.
yes i know exactly what u mean, i almost got arrested because of this, some lil **** was like i have to pump it for you and i was like **** off and they called cops and **** so i left, drove back on cali border, got gas, and went back to oregon lol... its such a stupid ******* law
yea problem is tho when i tried to just keep clicking the nozzle when i stopped it seemed like fuel was coming out of the tank. could have been i was retarded and pulled it out while i was clicking but i don't think i'm that senseless and retarded lol. and unfortunately i gots an 01 a4 and i have the module that masters can't fix... and i can't get my car to pass inspection with the brake light.... and i can't put the title under my name from the previous owner without it.... fml..
