Can't Stop 1.8 Rear Coolant Housing Leak
Old Oct 9, 2011 | 08:27 PM
mtnxtreme's Avatar
Default Can't Stop 1.8 Rear Coolant Housing Leak
I had a leaky rear coolant housing, ordered a new one from RAI with all new O rings, the housing came with an O ring mounted in the flange to block and another in a separate sealed bag, but they were both the same O rings. I mounted the one from the separate bag on the right side flange with the 2 bolts, it leaked. I noticed the original seemed a little thicker, so I went to Audi with the housing and they gave me another O ring , same size as RAI, so I figured this time let me put some black RTV on it, bolted it up,let it dry overnight, still leaked, now im pissed. Does anyone know if there is a special size O ring for it, every where I go they only have American size, no metric O rings. Is this a well known leaking spot, maybe the metal tubing that goes on the flange of the housing is the problem? Also I had a blue temp sensor, figured I'd replace it while apart, they sent me a green one, called RAI, the guy said as long as the plug is the same, the color don't matter, but now my little red thermometer on the dash flashes when I run the motor, can anyone help, shed some light on this problem?
Old Oct 9, 2011 | 08:58 PM
ckrummy's Avatar
check your coolant temperature sensor, mine was leaking right through the center of the plug, cost me $30 in coolant for a $15 part.
Old Oct 9, 2011 | 10:58 PM
mtnxtreme's Avatar
It's new with a new O ring, and I can see it dripping from the bottom of the flange with a mirror. Did you replace your sensor with the same color?
Old Oct 10, 2011 | 08:00 PM
ckrummy's Avatar
Yeah i replaced blue with blue, but mine didn't come with an o ring so i had to use 2 o rings to get a good seal. On mine it looked like it was leaking from the flange but it turned out to just be running down the coolant elbow.
Old Oct 11, 2011 | 02:05 PM
mtnxtreme's Avatar
Just spoke to ECS tuning, they sent me the wrong Oring, the 2 O'rings are the same diameter but different thickness
Rn3037
Jun 28, 2014 06:30 PM
flipkid
May 27, 2013 11:57 PM
Ralf5k
Sep 23, 2012 09:32 AM
mtroxel
Jul 28, 2012 12:07 PM
Jjedlicka
Aug 2, 2010 09:13 AM
