car won't start
Old Mar 7, 2012 | 12:51 PM
A4 2000's Avatar
Default car won't start
I disconnected the battery, reconnected it and no luck. Recently put in a new cts so it's not that. Checked for codes, nothing either. The batt is at 12V. Maybe a bad fuel filter? I have no idea if it was ever changed. Should I start there? Thanks in advance.
Old Mar 7, 2012 | 03:12 PM
bmoore98A4's Avatar
Is there spark? Fuel? Compression? Ide start there. filter would not prevent starting. its just a plastic piece filled with coffee filter paper
Old Mar 7, 2012 | 05:58 PM
chocalotstarfish's Avatar
Super Moderator
Is it cranking? Are you getting spark?
Old Mar 7, 2012 | 07:15 PM
A4 2000's Avatar
Yeah. It's cranking, I'm getting spark. I'm guessing it might be something fuel related since it almost started and then died. Could the crank shaft position sensor have something to do with this?
Old Mar 8, 2012 | 04:26 PM
A4 2000's Avatar
Well, I ordered a new fuel pump relay to see if that might be it. It's located somewhere under the steering wheel right? Crossing my fingers.
Old Mar 8, 2012 | 06:43 PM
Super Moderator
Have you tried pulling codes?
Old Mar 8, 2012 | 07:34 PM
M5S5's Avatar
Tech Certified
Did you check check the plugs for fuel? If the plugs are wet try a clear flood. Hold accelerator pedal to the floor and crank the **** out of it & see if it starts to go.
Old Mar 8, 2012 | 08:47 PM
audiltr's Avatar
had the same problem few years back ended up being the engine coolant temps sensor
Old Mar 9, 2012 | 02:35 AM
A4 2000's Avatar
It was the fuel pump relay! It was such a relief to hear the engine start. I had to hook up a battery jump starter though since the battery was pretty much dead from trying to start the car so many times.
Old Mar 9, 2012 | 06:27 AM
M5S5's Avatar
Tech Certified
Glad to see you got it fixed.
