CEL Code P0171 - Found the problem
Old Oct 4, 2009 | 03:22 PM
zeca's Avatar
Default CEL Code P0171 - Found the problem
I found the cause of the code to be the intake air hose (the one going into the MAF/Air Box) pinched at the bottom.
Looking at it from the top it looked OK, but the bottom of the hose was not inserted properly and let air in - bypassing the MAF. This probably happened when I last changed the air filter.
Found this out when I took out he MAF for cleaning and then when re-installing noticed that the hose was not going in OK. Had to move the hose clamp away from the "hose lip" (not just loosen it) and then applied a bit of lube to the hose lip and it went in OK finally.
Had been living with this for a while...much better now!
Old Jan 4, 2010 | 06:02 PM
boostin_A4's Avatar
you gotta a picture of that hose cause i got the same problem with my b6
Old Feb 24, 2010 | 02:15 PM
CHB73SB's Avatar
I too have this problem, the car just set a P0171 code. I would like to see a pic of this hose you are talking about.
Old Feb 24, 2010 | 04:47 PM
S_R_N83's Avatar
I just had the code too and it was the little air hose with the heat protection coming off of the manifold. It had a little tear in it.
Old Feb 25, 2010 | 06:16 AM
CHB73SB's Avatar
Thanks, it seems that the main cause of this code is unmetered air. I am going to try and smoke test it and see where that leads me.Thanks again.
Old Feb 25, 2010 | 10:46 AM
S_R_N83's Avatar
Yeah, its a boost leak somewhere.
Old Feb 25, 2010 | 12:15 PM
McGovs2.7TB5's Avatar
I had this code back in July and it was a bad MAF. This code is notorious for being tough to get rid of.
AudiZD
Jul 6, 2013 01:14 PM
flipflop
Sep 23, 2009 10:00 PM
llopez5
May 10, 2007 09:35 AM
A4speed
Sep 5, 2006 12:13 AM
jpez
Dec 19, 2005 05:16 AM
