CEL code P1338, Turbo whining.
Old Nov 23, 2010 | 08:31 PM
BoostLover97's Avatar
Question CEL code P1338, Turbo whining.
Ok, car is a 1997 Audi a4 1.8T.
Two things are wrong with my car:
1) I'm getting a CEL code P1338
2) My turbo (I think it's my turbo) literally sounds like a police siren.
I'm hearing this code is a pretty tricky one to deal with.
My turbo started making this noise after I replaced my water pump and thermostat I'm pretty sure.
If anyone can give me some help what would be amazing.!
Last edited by BoostLover97; Nov 23, 2010 at 09:32 PM. Reason: Too much un-needed junk in my first post.
Old Nov 23, 2010 | 11:12 PM
ImTheDevil's Avatar
Nothing crazy about the code - your cam sensor is bad. Check to be sure it's securely plugged in (it's on the front of the cylinder head centered over the cam sprocket). If it's plugged in well then it's probably bad.
As for the turbo, is the whine in sync with engine RPM? Does the whine get louder/quieter/different based on any certain criteria, such as when cold vs hot, steady cruise vs accelerating, etc?
Old Nov 24, 2010 | 11:01 AM
Well from what I know it changes with the rpm, at an idle you dont hear it, then at about 2000rpm its whining and up until about 4000rpm it gets louder then any higher than that everything is too loud to hear the sound. It does it really bad when the enging is cold or its cold outside. it also makes the sound when your cruising at really any speed.
Old Nov 24, 2010 | 01:14 PM
Ok, I uploaded 3 videos that might help:
http://www.youtube.com/watch?v=ADSbfwZXxNY
http://www.youtube.com/watch?v=Oe2mAU-1TEs
http://www.youtube.com/watch?v=Sv1hO-unXNU
Old Nov 25, 2010 | 09:10 AM
bump :/
Jeremy Decker
Jun 18, 2013 10:52 PM
89MustangGX
Jan 4, 2011 12:29 AM
zat0rsk1
Oct 11, 2010 09:51 AM
skoehle1
Jan 29, 2009 10:02 PM
zat0rsk1
Aug 29, 2006 02:50 AM
