Help with P1338 Code
Old Jan 3, 2011 | 09:04 PM
89MustangGX's Avatar
Default Help with P1338 Code
Hello, I have finally been working on my GF's 98 A4 2.8 Quattro that she inherited (I don't know a lot of history), but I'm looking for some help.
Cars starts, runs, and drives fine. Has 199k miles on it. Manual transmission.
Check engine light on -- and has been since I have known her (3+ years -- I know BAD!).
I pulled codes and got some that through searching led me to believe a vacuum leak, which I think I found and fixed (codes have not returned for a couple days since I have done it).
The only other code I pulled has me stumped. It is a P1338, dealing with the CMP open or short to B+ Bank 1. I searched and found a really wide range of threads dealing with all sorts of different scenarios.
I'm hoping to get some type of a list of things to check in order -- most common to least common on this car.
Thanks,
Adam
Old Jan 3, 2011 | 10:39 PM
hiwords's Avatar
http://www.audizine.com/forum/showth...1338-and-p0116
you can get a sensor from a parts car for cheap. bank 1 is the passenger side.
Old Jan 3, 2011 | 10:57 PM
Excellent--thanks!
I saw so many posts referring to everything except the sensor, I was convinced I needed to start someplace else.
Is this a simple swap or will I need special tools? I'm not even sure what it looks like, I will search for pictures or description unless someone has something they can post for me.
Adam
Old Jan 3, 2011 | 11:21 PM
hiwords's Avatar
so simple a caveman can do it ; )
looks very similar to that
Old Jan 3, 2011 | 11:36 PM
Tourbo24's Avatar
i just replaced that part like 2 months ago accept that i had bank 2 which was under the coolant tank on the backside of the engine. it was very tight in there so make sure you got small hands :P
Old Jan 4, 2011 | 12:23 AM
Great -- thanks guys!
So if Bank 2 is on the back and I need to change Bank 1, it should be on the FRONT right side, correct? Will it be under any covers or require disassembly or will I see it pretty easily? (I still have the plastic engine covers off from fixing the vacuum leak).
Adam
Old Jan 4, 2011 | 12:26 AM
Tourbo24's Avatar
i have the 2.8 v6 and for both the throttle positioning sensors and the o2 sensors it was bank 1 passenger side and bank 2 driver side. i believe that bank 1 is always the side where cylinder 1 is located.
Old Jan 4, 2011 | 12:29 AM
This car has the 2.8 v6 as well.
So sounds like Bank 1 is definitely the Passenger Side. Is this sensor in the front of the engine or in the back on the passenger side? Someone mentioned back for Bank 2, but I don't know if it's the same for Bank 1 or not. I want to know exactly where I'm going to look for it now that I know what it looks like.
Adam
Jeremy Decker
Jun 18, 2013 10:52 PM
BoostLover97
Nov 25, 2010 09:10 AM
zat0rsk1
Oct 11, 2010 09:51 AM
skoehle1
Jan 29, 2009 10:02 PM
zat0rsk1
Aug 29, 2006 02:50 AM
