Check Engine light + others
Old Jan 18, 2010 | 02:02 PM
willie7182's Avatar
Default Check Engine light + others
I swapped the transmission on my 96 quattro. After everything was hooked up and I turned the key and the car wouldn't start. The temp, oil, and fuel lights are all flashing and the check engine flickers and makes a buzzing sound.
I tried to download the codes using a 280 reader and it failed to link. Fuses all look fine... Vag-com is on the way. Anyone know what issue may be??
Old Jan 18, 2010 | 02:15 PM
dragonrage's Avatar
er, these might be obvious, but is your battery charged, and are the connections tight? Check for loose grounds?
Old Jan 18, 2010 | 02:26 PM
willie7182's Avatar
The battery does have a full charge and connections are tight. Something is preventing the starter from getting power...
Old Jan 18, 2010 | 08:49 PM
willie7182's Avatar
I wonder if my ECU is shot?
If so, will vag-com still work?
parlayin
Feb 10, 2010 12:33 PM
MrTigz5254
Mar 7, 2008 11:56 PM
huyaroo
Sep 12, 2007 03:37 PM
blanthony
Mar 25, 2006 01:18 PM
