Check engine load signal
Old Jun 24, 2008 | 07:57 PM
brimhall99's Avatar
Default RE: Check engine load signal
LOL well I doubt that he would do anything about it, it reads that its the Transmission transfer case contact plate C Short circuit to ground, is that something that is tough to fix or way expensive? anyone else have this problem
Old Jun 26, 2008 | 01:11 AM
brimhall99's Avatar
changed the MAF and the transmission code went away, debating on keeping the car or not, it is a 2000 a4 1.8 with 153,000 miles, if i keep it what are the major things i need to fix on it so i wont have huge problems i know the timing belt, anything else??
Old Jun 27, 2008 | 08:45 AM
CRAZYHAWK's Avatar
My car has 146K mi. I replaced the steering rack at 132K,
and the tie rod ends at111K.
Old Jun 27, 2008 | 05:14 PM
Tweaked's Avatar
MAF is the load sensor for the engine and trans...
Try swapping it out.
Old Jun 27, 2008 | 06:21 PM
auditech79's Avatar
Un-plug your MAF sensor when its running and see if it runs any better, if it does, you need a new MAF
Old Jun 27, 2008 | 08:34 PM
Tweaked's Avatar
ORIGINAL: brimhall99
I guess he solved the issue. I dunno why I skipped this post.[sm=wakeup.gif]
joeynach
Aug 27, 2011 06:57 PM
landie
Jul 15, 2011 11:29 PM
porschefan
Sep 24, 2009 07:24 PM
relliMmoT
Oct 20, 2008 12:32 PM
