Climatronic display oil pressure?
I know about holding the two buttons to display all that stuff but I've read how there is a second set of codes to be accessed that will display oil pressure? Anyone know how or even if possible to do this?
The only stock readings you can get for oil pressure are using a vag com and vagging instrument cluster, this will give you the status of the oil pressure SWITCH (so it either says pressure ok, or pressure low).
Finnie1967
Dec 5, 2012 02:45 AM
