cluster display
Old Jun 30, 2010 | 12:22 AM
Tourbo24's Avatar
Default cluster display
so the problem is that when it is cold outside it works perfect ( i can ready everything and there is no cut offs of any kind), but when the weather gets warmer the display just takes a ****. it isnt as bright as in cold weather and fades in some places which makes it very hard to read. is there a way to fix it or do i need to get a new cluster?
Old Jun 30, 2010 | 03:25 PM
joenelson7687's Avatar
Last I heard there was a recall on the clusters, but I'm not sure of the year that applies to. In any case, those clusters are expensive to replace and pretty much unfixable...atleast when it comes to pixilating. Just check and see if the recall applies to you.
Old Jun 30, 2010 | 05:22 PM
vgo's Avatar
vgo
are you sure that was legit recall? someone posted that hear but was an april fools joke.
it sure fooled me.
Old Jun 30, 2010 | 05:41 PM
flynnr's Avatar
lol no way...
there is a place that does it for $130 or so and guarantees it... not bad!
Old Jun 30, 2010 | 05:44 PM
Tourbo24's Avatar
all the pixels work its just that i can only ready it all in cold weather but when it gets warm its really blury and most of the top is just blank
Old Jun 30, 2010 | 07:29 PM
meloman's Avatar
I have the same exact problem, my top and bottom corners are pretty much impossible to read when it gets hot out
Old Jun 30, 2010 | 07:33 PM
jokeabus's Avatar
Mine does the same thing. There is a ribbon cable on the back of the instrument cluster that powers the LCD display, and with warmer temperatures the bonding on this ribbon cable allows it to come loose enough so that it doesn't make proper contact with the unit.
I found this on a forum a few weeks ago, but I have yet to give it a try. The basic idea is to add some double sided tape or rubber to the underside of the metal plate holding the display onto the unit, so that the cable makes better, more consistent contact:
Step 1: Take out the instrument cluster.
Step 2: Disconnect the plugs.
Step 3: Remove the remaining plugs.
Step 4: Remove the cover. Take out the screws and snap open the cover.
Old Jun 30, 2010 | 08:00 PM
Tourbo24's Avatar
thanks for the find, i might try doing this i hope i dont F it up even more LOL
gdavidson
Sep 28, 2010 09:40 PM
stayfocus18
Sep 2, 2009 02:24 AM
hotgue
Mar 10, 2009 12:01 AM
chivo818
Nov 11, 2008 09:47 PM
barryoy32
Jan 15, 2006 11:42 PM
