which cluster do i need?
Old Apr 26, 2013 | 04:08 AM
slyrapture's Avatar
Default which cluster do i need?
I just got a 97 a4 1.8t auto. It was cheap and is only temporary after totaling my car. The lcd in the center of the speedo cluster is gone. Not sure why. Can i just replace the display or should i just replace the entire cluster? And either way How do I know which display or cluster to get?
Old Apr 26, 2013 | 06:39 AM
Pbcrazy's Avatar
There is tons of threads about this very thing, take the time to google. But anyways as far as I know, you cannot buy the LCD separately. You can replace the whole cluster but this is a very common problem and it will be hard to find one without that problem, as when you replace the cluster the mileage of the car that the cluster came off of shows up, Not yours.
Old Apr 26, 2013 | 08:24 AM
CCA4's Avatar
You can buy LCD screens separately, I have two. However they're a pain in the *** to swap and if you aren't extremely comfortable with soldering and electronics, I wouldn't even attempt it. There's a guy on the 'zine who will swap them for you if you have the time to mail it to him.
Old Apr 26, 2013 | 09:15 AM
Mad Cow's Avatar
No point in another cluster, it'll be just as bad or worse. I've yet to see a B5 with an original, still working LCD.
Old Apr 26, 2013 | 10:53 AM
audinoob27's Avatar
Mine still works perfectly believe it or not! Haha
Old Apr 26, 2013 | 12:22 PM
slyrapture's Avatar
O. And i ment gone. I ment that someone removed it entirely. Not that it's not working?
Old Apr 26, 2013 | 03:00 PM
CCA4's Avatar
Aaaaaaaaand you just jinxed it. Your cluster will be borked by the end of the month
Gone completely, that's a new one. Replacing it should still be the same procedure, just won't have to deal with taking out the old one. Unless somebody really screwed things up inside the cluster taking out the old one. Do all of your gauges and idiot lights still work?
Old Apr 26, 2013 | 04:33 PM
Mad Cow's Avatar
If it's missing I'm guessing someone tried to take it out and damaged it beyond repair, so I would go with a different cluster. It's actually possible to change the mileage with just a regular blue vagcom cable and the right software.
Old Apr 26, 2013 | 06:18 PM
slyrapture's Avatar
If you want to see exactly what I'm talking about I can pm you a picture.
Nunem17
Aug 31, 2013 04:05 PM
audinoob88
Jun 29, 2011 10:29 AM
MartinCieslak1
Mar 21, 2010 07:33 PM
asutherland
Jan 22, 2010 09:58 AM
