Clutch lost pressure
Old Oct 28, 2010 | 05:00 PM
Gambit0714's Avatar
Talking
Originally Posted by Mike-2ptzero
Are you saying you can push the pedal to the floor when you start it? Because if you are then your clutch is acting normal. The normal pedal travel is to the floor and back up. The normal engagement/disengagement point on a stock clutch is right at the top.
So if the pedal resistance is normal when you push the pedal down and it returns to the top, clutch is not slipping and you can change gears without any problems then everything sounds fine.
The OP lost all pressure in the pedal when he went to push on it.
Yup, OK thought I had a problem.
Thanks
Mike-2ptzero's Avatar
Originally Posted by SilverDragon2001
The funny thing is that when I pressed it in and lost all pressure...it wasn't but a min or two later that it came back but if I did anything more than feather the gas I would loose it again and I was still able to get it to move in gear. I stopped running it in gear though didnt want to risk messing up the flywheel. I am towing it back from Gwinnett tonight...going to start tearing it down this weekend. I need your trailer...UHAUL is charging me like $70 with insurance.
My Trailer? I borrow one from a friend, but I think thats going to be a long haul seeing that I am in Murrieta, California. lol
BTW loved the steak place in PeachTree, GA and thumbs up to Wild Bills lol
Old Oct 28, 2010 | 05:04 PM
kayakman13's Avatar
Now what do you mean by RPM hang? When I shift, I notice that the RPMs hang up for a bit before falling, but I thought that was an aid to shifting, gives me time to find gear and usually is at perfect RPM when I let the clutch out.
And I dont go to either state school, but I'm more an OSU guy. Girlfriend goes there so I basically go there.
Old Oct 28, 2010 | 06:50 PM
Yes that happens because part of the flywheel is not allowing the whole flywheel to slow down as soon. Most people find it annoying. I found it very annoying since it makes bounching the rpms very slow.
Aspec
May 31, 2010 12:20 PM
tpc303
Jul 7, 2008 07:56 PM
thareals4
May 13, 2008 10:42 PM
jfa_16
Sep 12, 2005 02:17 AM
