Clutch replacement suggestion
Old Dec 8, 2010 | 05:28 PM
debasmit's Avatar
Default Clutch replacement suggestion
Hi,
I am looking for a clutch kit. Is the Sachs or Luk clutch any good? I use my car for normal daily use - no racing or anything. I was also looking in ebay and these are the brands I found - Luk, Sachs, Valeo, XTR and F1.
Southbend and Clutchmasters is quite expensive and I am not looking to spend that much.
Thanks,
Debo
Old Dec 9, 2010 | 12:13 PM
SVT_BRYAN's Avatar
Luk is quite good, that's what ECS puts in their RA4 stage 1 kit, which I just installed.
Stay away from XTD and F1, there are many horror stories about those failing in less than a year. Better to do the job right once than wrong twice.
This topic has also been covered many times and we've had quite a few clutch threads just recently in the past month. Search is your friend.
Old Dec 10, 2010 | 10:58 AM
debasmit's Avatar
Thanks for your suggestion! I saw the previous posts...most of them talk about Clutchmasters and Southbend. I ordered Sachs as I found that's the stock clutch. I ordered the organic disc....is there any difference?
Old Dec 10, 2010 | 02:01 PM
Mike-2ptzero's Avatar
That is the stock clutch that came on your car which is an organic disk.
A Clutch Masters FX100 for your car would have cost you $403.75 shipped anywhere in the USA using a coupon for 5% off the CM kits on www.ringer-racing.com
CM 228mm kit has 1800 lbs clamping load and the FX100 is a peformance metal backed organic disk, the stock Sach clutch is only 1300 lbs and uses a standard organic disk.
Old Dec 13, 2010 | 01:37 PM
debasmit's Avatar
Thanks! I went for the stock one... Sachs Organic Disk. It cost me $230 on ebay.
pmf94
Jan 29, 2013 05:32 PM
Nevalite
Jul 23, 2012 09:10 AM
mattr7786
Aug 14, 2007 01:25 PM
quattro_head
Sep 7, 2006 04:30 AM
yellow325ix
Jan 26, 2006 03:00 AM
