Code P0102
Old Apr 12, 2012 | 05:52 PM
Ineedhelp's Avatar
Default Code P0102
i have a cel code P0102 which is MAF circuit low input. I have cleaned the sensor and I was wondering what else I could check, like common spots where wires are pinched or heated. Thanks
Old Apr 12, 2012 | 06:31 PM
02A6Beau's Avatar
I cant really think of an area where the wires would get compromised to the point where it gives you a "low input" error. It is one of those things that is either connected or is not connected.
my only suggestions are double check the connector as that is a common weak point, or replace the MAF
Old Apr 14, 2012 | 12:07 AM
ImTheDevil's Avatar
Agreed with Beau - if it's not reading right and cleaning it doesn't help, it's likely bad.
Old Apr 14, 2012 | 10:41 AM
Ineedhelp's Avatar
Thanks for the replies. I was just hoping I wouldn't have to buy a new one because of the price, but now I have an excuse to upgrade it.
Old Apr 14, 2012 | 08:38 PM
Ineedhelp's Avatar
I was wondering if a maf from a 1.8t would fit on my 2.8
Old Apr 14, 2012 | 10:19 PM
crazyquik22023's Avatar
I had this code for a while on my previous 01 a4 1.8t. It ended up being the wiring was bad. One of the previous owners of the car rewired the maf wires for whatever reason. There are 4 wires. The one wire is a ground wire that gets connected to the MAF harness and another wire is an earth ground wire that just gets left open and not connected to anything in the MAF harness. The previous owner wired the ground and earth ground wires together which was causing the MAF to get no reading and gave me the p0102 code. Check out to make sure the wiring is in tact. If it looks like somebody previously did some kind of re wiring to the MAF check all the wires and make sure they are connected to where they should be.
Old Apr 16, 2012 | 08:03 PM
Ineedhelp's Avatar
I finally fixed it. I took the MAF off, took the back plate off, and sprayed almost a whole can of MAF cleaner into it. Then with the car running I cleared the code, last time I cleared it with the car off and it came back without even starting the car, and the code hasn't come back yet.
b00gs
Apr 30, 2012 12:03 PM
slamburgerz
Dec 24, 2010 12:53 AM
Msnickbroderick
Nov 5, 2010 01:30 PM
97A41.8t
Jan 21, 2007 12:08 AM
turbo
Jan 26, 2005 01:52 AM
