Code P0332. Buy a new Knock Sensor? Help
Old Mar 21, 2009 | 12:20 PM
HarryS's Avatar
Default Code P0332. Buy a new Knock Sensor? Help
I've got three codes on my 1998 2.8V6
P0332 (knock sensor #2, low input)
P1137 (Fuel trim too lean at idle bank1)
P1139 (Fuel trim too lean at idle bank2)
A search says either the knock sensor is loose or it's fried. Don't have the VAG scanner to test for the latter. I wonder if my Actron CP9180 can tell via its freeze frame or PID?
It's a big job to get to the knock sensor. Injectors, coils, TB, manifold have to come off. Lots of new gaskets. At least a day for an audi noob like me.
If I can't test the sensor, I might as well just buy a new one and replace it if I have to go thru all that work, right? Should I replace both? Is this an unusual problem?
I plan to clean the MAF sensor and run some Techron to attack the last two codes.
-Harry
Old Mar 21, 2009 | 06:18 PM
PolakA4's Avatar
u might also wana pull ur O2 sensors out and clean those of also so that when u done with everything it reads it corectly. u have to buy a special cleaner tho for the O2 ,its not expensive tho
Old Mar 22, 2009 | 11:38 AM
HarryS's Avatar
Good idea. Damn. Next car I get will have an inline six. Is the 4 any easier to work on?
JeffWitt
Nov 23, 2014 01:50 PM
shehateme
May 28, 2014 07:45 PM
crp0409
B7 Models
Jan 12, 2014 01:15 AM
davidp423
Mar 18, 2009 10:09 PM
bluesnapper
Nov 16, 2006 09:11 PM
