Cold Start Oil Circulation
Old Jun 19, 2012 | 02:44 PM
bmoore98A4's Avatar
Default Cold Start Oil Circulation
When I crank her over in the morning, The top end isnt getting any oil for about 2 seconds. I hate the sound, I hate the damage its causing, its gross haha
I am running 0w40, as per audis reccomendation. I am going to do an oil change in the next week or so to 10w30.
Besides an electric oil pump, what can I do to prevent this????
Old Jun 19, 2012 | 04:54 PM
livinglegend2100's Avatar
ive often wondered about the same thing. different viscosity oils havent made any difference in mine. the only way i can get it to NOT do it is to crank the engine and turn the key off before the motor actually starts. if i do that about 5 or 6 times theres enough oil circulated to sound like a normal engine when it starts. but i feel your pain. its a terrible noise.
Old Jun 19, 2012 | 05:06 PM
bmoore98A4's Avatar
GAHHHHHH someone chime in haha but thanks for that! Only gripe i have with that is my starter taking the beating. (225,xxx miles)
Seafoam is definitely going in my oil to hopefully clean out any gunk. There was an old recipe for ATF/oil if anyone has it.
Could valve lash help me out? She runs great, starts right up, good vaccum, good boost, pulls like she should. Just this sound is going to be the death of me! lol
Old Jun 19, 2012 | 08:02 PM
ImTheDevil's Avatar
Until the lifters pump up, it's going to clatter (that also could be because the CCT is driven by oil pressure too). Short of a pre-oiler setup, I know of nothing you can do but plug your ears.
Old Jun 20, 2012 | 12:23 PM
yea ive tried everything from super thin oil, to sea-foaminging the crankcase, oil stabilizer, full on engine flush, and nothing. i just keep good quality oil in it and change it often and learned to deal with it. make your exhaust loud like mine and you wont have to listen to your engine
Old Jun 20, 2012 | 01:36 PM
McGovs2.7TB5's Avatar
This sounds way worse for the engine than the 2 seconds before the oil has begun circulating.
Fwiw, I had a similar issue my old 1.8t, it went away after replacing the cam chain tensioner(CCT devil mentioned).
Old Jun 20, 2012 | 03:05 PM
c0r3y.af's Avatar
Mine has been that way since purchasing the car at 130k. I've tried a few different oil types and nothing seems to work. Seems super common though
Old Jun 21, 2012 | 01:02 AM
bmoore98A4's Avatar
Well thanks for all the replies guys. I think I'm going to go sulk now haha
Old Jun 21, 2012 | 04:01 AM
twoeightquattro's Avatar
Mine does the same. I used Lucas oil additive and fixed the lifter clatter noise but still does it when cold starting. Not sure what to do about it but it goes sway 3 seconds after I start it so not terribly bad
Old Jun 21, 2012 | 08:15 AM
aragorn's Avatar
Theres a 1 way valve screwed into the back of the oil filter housing. If its giving you the death rattle for a second or two on startup then going quiet, chances are this valve has come loose.
