condition of axle
Old Oct 19, 2014 | 09:28 AM
Steinrawr's Avatar
Default condition of axle
Hey. I just need an opinion on this axle.
https://i.imgur.com/nl30VyZ.jpg
It got some rust on the surface, and the top layer can in some places be peeled away. I have a bad CV-rubber joint, and just need to replace that, but I don't have tools to access the bolts that connects the axle to the gearbox, so therefore I'm just going to save some time letting a mech do it for me. And when the garage takes this job, I'm unsure if they think the axle will be good enough.
I'm going through an EU-control (Norwegian "MOT") and this is the only fault i have. What do you think?
Old Oct 19, 2014 | 11:45 PM
jeckel20003's Avatar
If the rubber boot is all that is wrong with your CV axle, you can buy a kit to replace the rubber boot with a new one. I'm not sure if it would be cheaper than buying a used CV axle or if you could easily find a rubber boot kit near you. Here's a link to the kit I'm talking about so you get an idea of what is included. As to your original question, the CV axle in the picture wasn't as rusty as I was expecting and I don't think you would have any problems with it.
Old Oct 20, 2014 | 05:29 PM
Mad Cow's Avatar
That's perfectly fine, surface rust doesn't hurt anything.
Old Oct 29, 2014 | 09:15 PM
mtroxel's Avatar
The tool you need is triple squares, and they're a lot cheaper than taking it to a shop.
And, if the joint isn't making noise or full grit, you can just change the boot without taking the axles off. You don't even need the triple squares.
billymac122
Jul 25, 2014 01:06 PM
spit144
Dec 9, 2008 03:29 PM
kevintt
May 8, 2008 09:57 PM
drifter22
May 26, 2007 06:26 PM
bajamoon
Feb 26, 2006 01:34 AM
