Control Arm question
Old Jun 25, 2014 | 09:23 PM
elduderino200's Avatar
Default Control Arm question
Broke my front, lower, curved, control arm this morning. Luckily I was able to limp home. It also wasn't a surprise it broke as it was clunking at me already (though yes, I should have replaced it before it actually snapped. Live and learn).
Is it okay to replace just the broken one? Should I replace both lower on the front-left? All 4 on the front-left? All 8 on the front? etc...
Also is it sufficient to just replace the control arm or should I buy bushings as well (or anything else)?
The car's got 160k on it so it's not as though I need this to last another 10 years... That's not to say I'm neglecting it in any way, but if this something that can just be replaced as it breaks until I put a brick on the gas and send her off a cliff, I'll be content. If however not replacing both causes earlier failure, I'll replace both.
Thanks for any help!
Old Jun 25, 2014 | 10:39 PM
Well I bought both front left lower arms. WAY cheaper on amazon than ECS but one on amazon said it wouldn't fit when it was the exact same part on ECS and said it would. And vice-versa for the other... so we'll see how this goes...
Old Jun 26, 2014 | 08:46 AM
A4TurboGuy's Avatar
You can get adjustable control arms. That way you can adjust your camber without having to mess with the sub-frame.
Old Jun 30, 2014 | 11:27 PM
Okay I got the control arm replaced. Turns out the old ball joint just fell out. Seriously. I hope the new one lasts a bit longer...
I also bought the straight arm that I didn't end up replacing because I had such trouble with the curved one. So now I have a spare control arm I don't need. I'm going to try and return it but I doubt itll work.
edwin2424
Mar 13, 2014 03:33 PM
shortyxc
Sep 22, 2009 11:35 PM
PTEmbree
Apr 30, 2009 12:21 AM
kickasS4
Oct 29, 2007 09:49 PM
iowaboostin
Aug 8, 2006 10:20 AM
