Would these wheel specs fit a B5 A4?
Old Jun 27, 2014 | 10:21 PM
OldAudiA4B5's Avatar
Default Would these wheel specs fit a B5 A4?
OFFSET: 30P OR 45P
STUD PATTERN: 5/112
Is more info needed?
Old Jun 28, 2014 | 03:32 PM
MetalMan's Avatar
The most "normal" tire size for that would be 235/35/19. My car came with 19x8.5 et35, 235/35/19, and was mildly lowered. The front tires would hit the fenders pretty hard, so I got the fenders rolled. The rear was fine. 30 offset would be even worse, and I wouldn't recommend it with the tire size I listed. 45 is not enough offset and would require spacers (about 10mm) to clear the spindles, and would still require the front fenders to be rolled.
Old Jun 29, 2014 | 06:41 AM
How about
18" x 8"
PCD 5X100
Offset: 45mm
215 35 18 tyres
or
SIZE/WIDTH: 18 X 8
PCD: 5 x 112
OFFSET: 45 ET
Would either of these scrub or require a fender roll?
Old Jun 30, 2014 | 11:17 AM
MetalMan's Avatar
215/35/18 would be smaller than stock-size tires by about an inch in diameter.
Is a correctly-reading speedometer important to you? If so, you need near-stock-size tire. In 18" this means 225/40/18.
ET45 should be okay with 225/40/18.
Old Jul 1, 2014 | 02:31 AM
Thanks for the info.
a3driver
Nov 21, 2009 03:06 AM
unclesol
Jun 4, 2008 11:10 AM
mrlawrence
Mar 28, 2007 04:04 PM
mrlawrence
Mar 25, 2007 02:22 AM
jinxxycat
May 3, 2005 05:32 PM
