Conventional Oil in a car with 150K
Old Apr 16, 2009 | 02:59 PM
JimyYeags's Avatar
Default Conventional Oil in a car with 150K
So I had an oil leak about 4 weeks ago... Found out the pan was cracked... so I replaced with a new pan.. now it s leaking a a bit again just enough to run back on the manifold and give me that pleasant smell in the morning when the car is first warming up... I am 98% sure if coming from the pan again. I m using Mobile 1 currently, however was thinking about going conventional and to a heavier weight to see if the leak or seap stops... what do you guys think... 98 2.8 A4 with 150K on it... Runs like a champ other than the oil leak and the nasty smell in the morning. Oil levels remain pretty muh the same between changes.
Old Apr 16, 2009 | 06:54 PM
redline380's Avatar
Legal Moderator
just say NO! to conventional. it would be like running 87 octane. sure, it works, but why take the chance?
Old Apr 16, 2009 | 07:23 PM
Interceptor's Avatar
No, stick with synthetic and keep going. I switched mine to synthetic 5w40 and it loves it. Yes you can have a possibility of seepage with the synthetic on an older engine. Just replace the gaskets if it leaks. It's worth it.
Old Apr 16, 2009 | 08:25 PM
juxsa's Avatar
with your 2.8 try running some Rotella T 15w40. Its a really good oil and thick enough it might not leak.
TheMilkMan
Jun 15, 2011 09:00 PM
Brbarlow145
Feb 17, 2011 01:23 PM
proxeyed
Jul 10, 2010 08:02 PM
mzo0163
Apr 15, 2010 04:51 PM
Tourbo24
Feb 11, 2010 10:37 PM
