coolant flange o ring size.
Old Apr 7, 2011 | 04:33 PM
Audacity's Avatar
Default coolant flange o ring size.
have a leak from the coolant flange to the metal pipe that leads to the top of the radiator. i took it all apart today o ring looked fine, so i put it back together thinking that maybe a retorque would fix it but it didnt, must just be age getting to the oring. anyway my question is anyone know the size of the oring that i need?
Old Apr 8, 2011 | 09:36 AM
Audacity's Avatar
i didnt really think anyone would know. guess ill have to just hunt one down.
Old Apr 8, 2011 | 10:52 AM
CCA4's Avatar
Believe you need this little guy
Old Apr 9, 2011 | 06:39 AM
fastcompany's Avatar
no don't do it. the flange is not expensive. and its a plastic p.o.s. they warp thats why they leak. if you replace the o-ring your just wasting time to see that it still leaks after you have it filled back up with new coolant.
Old Apr 11, 2011 | 07:13 PM
Audacity's Avatar
the flange itself was replaced
with the o Ring that I took out. the ring on the block side was replaced so even if I was to replace the flange I will most likely need a an o ring anyway
Old Apr 11, 2011 | 10:01 PM
chivo818's Avatar
I changed out the flange and oil cooler yesterday, having the same issue. I orderd the wrong o-ring had to use the old one.
Old Apr 12, 2011 | 10:53 AM
Audacity's Avatar
where did you get the ring
and what size so I know not to order it.
jhsoccerodp
Dec 5, 2008 10:48 AM
nflea7
Jun 6, 2008 11:03 PM
carguytt987
Sep 10, 2007 11:21 AM
andyboy007
Sep 6, 2007 10:50 PM
