Coolant temp sensor
Old May 19, 2010 | 01:18 PM
predakota's Avatar
Exclamation Coolant temp sensor
Where is it? I have a 1996 Audi A4 with the 2.8 v6 i need to replace this car someone help a newb out please.
Old May 19, 2010 | 08:16 PM
bkraska's Avatar
Its in the rear coolant line. Look way back, top of the engine, close to the firewall and you will see the coolant line going across the engine. The coolant sensor will have green or blue base with a clip holding it down into the coolant line and an electrical connector on the top.
Old May 20, 2010 | 01:20 AM
A4 2000's Avatar
Sorry to thread jack, but is this in about the same location on the 1.8? Lately when I make a quick stop after driving for a little while,and start the car back up again, the temp gauge goes higher than normal and then gets back to normal after about a minute. That's not normal right?
Old May 20, 2010 | 10:48 AM
predakota's Avatar
so on the back of the motor what side left or right?
Old May 20, 2010 | 05:08 PM
lumend13's Avatar
can someone post a pic? mine should be here friday from ecs
Old May 20, 2010 | 06:04 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
The coolant temp sensor on the 1.8T is on the coolant flange on the back of the motor.
Old May 23, 2010 | 04:25 AM
A4 2000's Avatar
Ok, thanks. I found it today. It looks pretty easy to get to.
burak
Oct 23, 2009 07:21 PM
dhenson2342
Mar 14, 2009 08:04 PM
JL AUDI
Mar 9, 2006 01:38 PM
