Coolant Temp Sensor/Location?
Hi, does anyone have a picture of where to locate the coolant temp sensor?
And the replacement sensor has to be the green one? A temp sensor from like Murrays won't work?
Thanks in advance.
Thanks in advance.
i forget the color stuff, i think its different between the years. call the dealership and confirm which one you need.
as for location, its in the coolant flange at the back of the block.
http://www.audiworld.com/tech/eng76.shtml
http://www.audiworld.com/tech/eng47.shtml
Lefty, it could be that but it could also be a stuck thermostat. If the t-stat is stuck open it'll take a long time to get up to temperature, and at least on the 2.8, this seems to happen a decent amount. If it does on the 1.8T also, at least that one can be changed fairly easily. My understanding on the 2.8 is that the t-stat is behind the damn t-belt tensioner.
Well, doing the sensor is kind of a no-brainer in that they're known to be problematic in the A4, they're only about $20, and they're easy to change. I'd do that first, and see if it helps. If not, then go for the thermostat. Chances are very high that it's one of the two.
