Coolant Temperature Sensor? 1999 1.8T, AEB
Old May 31, 2012 | 05:29 PM
  #21
pradipsahu's Avatar
Talking Update
Just an update - about 30 days later and still running strong. I hope I don't jinx it...
Old Jan 2, 2013 | 07:59 PM
  #22
pradipsahu's Avatar
Lightbulb Bad Ground
The no start condition returned again, most likely due to the cold weather. After a little bit more electrical testing, I finally was able to pinpoint the problem. It was a bad ground. I am confident of this because I am now able to repeatedly reproduce and overcome the problem.
It appears that the original grounding point even after cleaning, etc. was not providing sufficient conductivity. So there wasn't enough current whenever trying to re-start in the cold, rain or even just after a few minutes of running and trying a re-start. The battery likely wasn't re-charging quickly enough or completely (which is probably why the alternator gauge readings looked a little high during the no-start), and there wasn't enough current getting through to ignite the spark plugs until the battery "rested" for a while.
After I attached the negative terminal of the battery to a new grounding point with good conductivity, the problems went away. It even worked when I experimented with the battery about 25% to 35% discharged.
Hopefully, this will help someone!
williagw
Feb 13, 2015 01:58 PM
DanaB6
Apr 22, 2012 02:48 PM
chris36
Feb 28, 2011 03:04 AM
maxdamage
Nov 15, 2010 04:47 PM
warmachine000
Apr 14, 2009 11:29 AM
