Correct Tire Size: 17" Rim.
Old Oct 19, 2009 | 03:55 PM
SLVR99A4's Avatar
Default Correct Tire Size: 17" Rim.
Going from my stockers to a 17" rim size. I need to know what you all recommend for a tire size; 225 45 17 I assume is recommended from the research I done. Does this look the best for stock suspension? I heard a 55 side wall helps fill out the fender wells better; I currently have the 225 55 16 aluminum spoked oem wheels on now. Any help or opinions would be greatly appreciated. Thanks again!
Old Oct 19, 2009 | 06:44 PM
kriptonik's Avatar
What is the width of the wheel?
Generally, the width of the wheels determine what size tires you get. Also you need to know which look you want; whether you're gonna go with full-squared tires or stretched.
With 17's, I'd personally run ____/45/17. You could run thicker profile but you will have to adjust the speedometer.
Old Oct 19, 2009 | 08:38 PM
Mike-2ptzero's Avatar
225/45/17 is the correct size. You can go 235/45/17 but they will tend to rub if on a 8" rim. You can go 235/40/17 but they will be a bit on the small size.
You really dont want to go taller then 25".
Old Oct 20, 2009 | 07:56 AM
SLVR99A4's Avatar
Thanks Mike! The rims are a 7 1/2" rim so a 225 or 235 45 17 would be the ideal choice. I just want the fuller look since I do not plan on lowering or doing any suspension work to the car. What are you running on your car?..that set-up looks very nice withing the wheel well. Thanks.
Old Oct 20, 2009 | 09:57 AM
I run 225/45/17's in my car which has Intrax springs on it.
Old Oct 20, 2009 | 11:45 AM
SLVR99A4's Avatar
Hence the awesome stance! Well, hopefully I won't have too much fender gap that it makes it look off. 235's would give a little more sidewall staying with a 45 series, correct?
Old Oct 20, 2009 | 12:46 PM
Yes it would. I used to run 235/45/17 but they liked to rub.
quatroben2007
B8 Models
Apr 19, 2014 01:08 PM
Sweetlou21
B7 Models
Mar 21, 2014 11:03 AM
CallawayZ06
Feb 1, 2012 09:46 PM
jo2valdez
Jul 24, 2010 08:15 AM
Philthykins
Mar 17, 2007 04:19 PM
