a couple of concerns
Old Aug 27, 2010 | 01:22 PM
theflash's Avatar
Well you have to remove the nut holding the top of the dip stick, that's a must. Not a big deal since you don't have to remove the dipstick itself. I also used a bungee cord to hold the fuel lines up and out of the way a bit. Makes it a lot easier to put back in.
Edit: Keep in mind I also took out the airbox. One bolt on the left, pull it out, takes what 5 seconds? Then you can move some of the wires around. You may also have to bend the little piece of flexible heat shielding, then bend it back to where it was after you're done.
Old Aug 27, 2010 | 02:00 PM
Tourbo24's Avatar
i got it out and man it was a pain in the *** to pull the gasket out. it was in decant condition but the part where there is this thick piece that goes in a groove it was kinda melted in there. now i am just cleaning off the sides where the new gasket will go and will be ready to put it all back together.
Old Aug 27, 2010 | 03:26 PM
Tourbo24's Avatar
haha when i started doing this i though it would take me like 1h or a little more. it ended up being 3h hahah but i took my time plus it was the first time i ever had to do a valve gasket cover change
Gazzmonkey
B8 Models
Nov 19, 2013 06:47 PM
rrussel9
B7 Models
Aug 27, 2013 09:36 AM
Josh32
May 19, 2013 11:52 PM
03A46speed
Mar 28, 2011 03:12 PM
rradovitch
Mar 6, 2008 12:13 PM
