CRACKED HOSE....FUNCTION?
Old Apr 23, 2008 | 10:15 AM
SLVR99A4's Avatar
Default CRACKED HOSE....FUNCTION?
After recent starting issues with my car I located a 1" diameter rubber hose that is severely cracked and should be replaced ASAP but have no idea of it's function. Unfortunately I do not have a picture of this hose but it's location is directly underneath the intake plenum/ throttle bodyto the left of the dipstick. It seems to be coming out of the block and is not under pressure or vacuum as I tested it; may be a recirculation/ ventilation hose? Its pretty much saturated with oil too. Any advice or comments relating would be appreciated, thanks.
Old Apr 23, 2008 | 10:25 AM
TDRILL's Avatar
Default RE: CRACKED HOSE....FUNCTION?
Are you talking about your crankcase breather hose? They are more like plastic than rubber, but they wrap around the back of the engine and attach to some other things back there. It just recirculates unburnt hydrocarbons back into the intake. It can get pretty oily and gunky. Seems to be a pretty popular thing to break because it is fragile yet is in the way when you work on many things.
Old Apr 23, 2008 | 11:04 AM
SLVR99A4's Avatar
No its definitely not the crankcase ventilation pipe. This is a rubber hose on the right side of the engine down near the block under the intake manifold. If you look down through one of your plenums you can see if. It is an elbow shaped hose about 1 to 1-1/2" diameter so I can't just replace it with regular hose; its a fitted section which stinks. I definitely need to figure out its function before continuing to drive it. I've been searching like hell to get a picture of it and it's location.
Old Apr 23, 2008 | 11:06 AM
hiwords's Avatar
pm auditech79. he's got the full service manual cd thingy majiggy.
Old Apr 23, 2008 | 11:18 AM
SLVR99A4's Avatar
After searching ECS's website I think it may be a heater hose coming off the block. Damn I thought it may have been something performance related I could have fixed.
Old Apr 23, 2008 | 06:01 PM
akielb's Avatar
does it look like step #3
http://www.passatworld.com/forums/sh...d.php?t=196909
Old Apr 24, 2008 | 08:15 AM
SLVR99A4's Avatar
Yes! Thank you so much! So it is PCV related, I wonder how much of this will effect my performance other than the strong oil smell I was getting inside the cabin. My hose is extremely cracked right at the 90* elbow.
*Note above pics jacked from passatworld.com. Thanks guys!
Old Apr 24, 2008 | 11:08 AM
chaos92287's Avatar
yeah thats common and yeah its causing a vac leak so fixing it will get you some power back.
Old Apr 24, 2008 | 11:28 AM
SLVR99A4's Avatar
Really? Even if it's just crankcase ventilation? That's so great to hear considering I have been experiencing vacuum issues for a while now. Searched my car up and down and nothing, could not find any issues what so ever. Can't we just eliminate vacuum with these cars and the related constant problems that it creates? Kidding.... Thanks Chaos.
bmob222
Aug 30, 2013 03:05 AM
alan93
Mar 4, 2010 08:06 AM
oneg
Sep 9, 2007 01:26 AM
keko2004
Sep 5, 2007 03:07 PM
QuattroAvantT18
May 26, 2005 11:07 PM
