Crank shaft position sensor Location
I believe its at the rear of the engine facing the radiator going to a grey plug. Bently does not give a good description on the 1.8 only actually for the 2.8 and it still is not a good one. On the 2.8 diagram it shows going into the ecm via the 3 pin harness connector. Sorry hope this helps to some degree.
neomaxddr
Apr 1, 2009 03:16 AM
