Crazy engine break?!
Old May 23, 2010 | 08:16 AM
  #21
hiwords's Avatar
you sure it's not your tires rubbing? lol. that's really weird i've never heard of that problem before. you are in 5th when it happens though right?
Old May 23, 2010 | 08:24 AM
  #22
chocalotstarfish's Avatar
Super Moderator
LOL she is getting lifted on Wednesday hence the realignment! I'm going to 24.5gtf to help with the massive rub of the fenders! And yes only in 5th gear.
Old May 23, 2010 | 09:44 AM
  #23
hiwords's Avatar
try to see if you can do the same thing in neutral. if it doesn't ever happen in neutral, you can rule out the engine.
Old May 25, 2010 | 05:20 PM
  #24
Super Moderator
Ok, Got it to do it today with no one behind me was able to clutch and it went away I was just coasting like normal, which leads me back to the engine with no idea what it can be!
Old May 25, 2010 | 05:40 PM
  #25
bradtyler02's Avatar
I'm still leaning to either a DV or waste gate problem messing with your turbo.
The army has a vehicle that uses and "exhaust brake" which literally blocks off half the turbo on the exhaust side, significantly reducing engine power to help slow the vehicle down. Just something to consider.
Old May 26, 2010 | 07:48 PM
  #26
Super Moderator
Alright was able to get ahold of a vag-com and popped:
17913 - Throttle Idle Switch (F60): Does not Close or Open Circuit
P1505 - 35-10 - - - Intermittent
I reset and now and going to wait and see if it comes back! If so next route?
Old May 26, 2010 | 08:23 PM
  #27
JETSPEED333's Avatar
SoCal Crew Member
Originally Posted by JETSPEED333
so when you let off the gas the car slows down alot faster than normal? recent brake job? maybe the brakes are applying some unnesessary pressure?
auto trany? not gearing correctly??
i think i got it.... how about the IACV.... could cause vacuum reading to be wack!
I was close! =)
Old Jun 4, 2010 | 09:02 PM
  #28
Super Moderator
Ok Guys what to do? Got it to do it again and ran vag and sure enough it's back! Easy fix? Replace???
Old Jun 4, 2010 | 10:11 PM
  #29
hiwords's Avatar
daym. try cleaning the throttle body first. my friend's 525i wouldn't idle at all so i cleaned the MAF and it idled fine. basically, it's a switch on the TB that tells the TB to stay partially open so the car can idle when you're off the gas peddle. since it's happening intermittently, it may just be dirty. since you have the 1.8t you can easily access the TB
netoLopez
Aug 20, 2010 11:12 AM
canuckA3
Jun 19, 2008 07:55 PM
a4ever4a
Oct 14, 2007 01:49 PM
captnmorgan
Oct 27, 2005 11:38 PM
Meradin
Jun 20, 2005 01:04 AM
