cruise control issue b5
Old Apr 6, 2009 | 10:54 PM
mat8980's Avatar
Default cruise control issue b5
my b5 cruise control was acting up... worked great at first but then started stop working while it was engaged, then would only engage sometimes, now wont engage at all... is there a fuse i can replace or is it something bigger in the engine?
Old Apr 7, 2009 | 12:59 AM
kriptonik's Avatar
Old Apr 7, 2009 | 02:30 PM
Interceptor's Avatar
I tried this and swapped out my switch and it did not work. Next will be that damn pinky and the "brain" unit behind the glove box. Buddy can solder so we'll give that a try.
Old Apr 7, 2009 | 03:02 PM
kkinzli's Avatar
Member
Check with a junk yard. I replaced mine recently for $25 and my cruise has been working great for 2 months now. You are going to have trouble soldering because half of the circuit board is covered in a weatherproofing coating that prevents the solder from holding correctly.
Old Apr 8, 2009 | 04:53 AM
AudiCoupeV6's Avatar
Member
Just resolder all of the solders in the controlunit and you should be fine!
There is a protective coat over half of the circuitboard but you can remove this by using thinner.
yacoman89
Jun 18, 2014 08:55 PM
yacoman89
Jan 4, 2011 05:18 PM
bud8817
Jun 24, 2009 05:38 PM
Belligerenceâ„¢
Mar 5, 2007 05:24 AM
snogoer
Oct 27, 2005 03:36 AM
