damn starter
Old Mar 13, 2011 | 10:13 PM
bradtyler02's Avatar
It's wired up exactly how it came out. As a matter of fact, I don't think I could mess that part up the way the wires are run.
Old Mar 14, 2011 | 02:09 AM
Andrew149's Avatar
does anyone know the starter issue's in the 1.8t when ever i start up mine it has a bad grinding noise and goes away 2 sec's later
Old Mar 14, 2011 | 08:11 AM
sounds like the teeth on either your starter or the fly wheel and wearing out.
Old Mar 14, 2011 | 11:50 AM
FASTER's Avatar
Tech Slut
maybe you put the lil 50 clip on the wrong post (the slip on clip).
Old Mar 14, 2011 | 12:07 PM
jdahlen24's Avatar
Brad, just curious. How did you determine that the starter was bad, as opposed to something else like the ignition switch?
Old Mar 14, 2011 | 06:45 PM
truthfully, I used the WAG method. The battery is good, and the starter would click once, but not turn over. I was 90% sure. I'm going to climb under with the multimeter and investigate further.
Old Mar 17, 2011 | 09:14 AM
Alright, I spent a couple hours doing more troubleshooting last night, and here's what I've found so far... Main voltage from the battery to the starter is good. The start relay (in socket 13 of the relay plate) is good, and there is voltage at the socket with the key in the start position, which tells me the clutch position sensor works, and the ignition switch is good as well.
One last check before I rip the new starter out and take it to get tested... If I check the voltage at the starter on the smaller wire, I should get 12 volts with the key in the start position. If I have that, then I'm trying the screwdriver test...
Old Mar 17, 2011 | 09:24 PM
  #18
Well, I fixed it. Turns out the "start" and "relay" prongs on the new starter are swapped a complete 180*, so when I put the new one in, and wired it the same way the old one was, I had the smaller start wire on the wrong prong. So, in the end, all is good, the car starts with no problems, and I was correct about the starter being bad.
I don't think anyone was really paying attention, but years from now, if someone actually uses the search feature, I wanted to make sure this thread was complete.
Old Mar 18, 2011 | 11:46 AM
  #19
jdahlen24's Avatar
I was paying attention. Glad you got your starter working. Btw, you have an extra "http//" in the URL in your sig. It no workee.
Old Mar 18, 2011 | 04:42 PM
  #20
yep, someone pointed that out, and it's good to go now. I tested it.
airguard350
May 30, 2011 08:04 PM
CoBra03TerminAtoR
May 3, 2008 10:30 PM
mr.cAp
Feb 11, 2008 09:28 PM
bluovalguy
Jun 14, 2005 11:53 AM
