DASH LIGHTS-Brake/ABS
Old Apr 7, 2012 | 09:44 AM
morpheous's Avatar
Originally Posted by markymarc
Personally I've never re-positioned them. I've always just replaced them, seated them right, and its worked. It's either bad, or the cable is nicked. If you've found it, looks like a cigarette lighter plug from a car, the wire for the right rear sensor goes up under the right rear seat and then plugs into a module underneath the rear seat.
They can be hard to get out. I would just get a new one and replace it. Also, once the sensor is fixed, the lights on the dash will go out without VAG with turning the car off and then on, however the code will still be logged.
Well,my ABS light is solid on the dash,not flashing or anything,the ABS isn't lite,either. So my best guess is,the rear wheel speed sensor isn't seated properly. I had both rear,wheel bearings,replaced.
I didn't know before hand but now i know,that i should have told the mechanic,to disconnect the wheel speed sensors,from under my rear seats and pull them out as to keep the sensor,connected to the hub,while pressing out the bearings.
I doubt its damaged,perhaps dirty or simply not positioned properly,not in far enough or in too far. I'll turn it counter clock wise and clock wise,so it screws into place,for maximum contact.
I'm going to drive down to my mechanic,today to get it sorted.
Old Apr 8, 2012 | 11:26 AM
jeckel20003's Avatar
My Audi has 240k miles and I broke both of my rear sensors when trying to remove them so I could do wheels bearings. If they're the original sensors, they will really be stuck in there and you probably won't get it out without breaking it. So the mechanic could have broken one if he tried to remove it. After I replaced one of mine it said it was bad so I took it out and found metal shavings stuck to the metal end that goes in the hub. After I cleaned it off, it worked fine. Both of mine I just tapped on the end until they were seated as far in as they would go and they worked fine.
Old Apr 8, 2012 | 11:39 AM
morpheous's Avatar
See my thread,labeled"ABS Wheel Speed Sensor Code" on the main page,for my resolution of my wheel sensor issue.
Old Apr 8, 2012 | 06:23 PM
Davidiot's Avatar
Originally Posted by ou2mame
the abs sensors just stick in there... if they're too close, too far, metal on them, you'll get the abs and brake lights to come on..
Can you please elaborate on this a little, I changed my calipers in the front, and after this I have the flashing ! light and abs lamp lit. What could have caused this ? Have I positioned something incorrectly on the caliper ?
Thanks
EugeneTakoev
Sep 7, 2013 10:34 PM
nize
Jun 21, 2013 01:16 PM
SAudi
Aug 20, 2009 11:36 PM
blockp
Jan 30, 2008 01:04 AM
alan93
Jul 6, 2007 09:49 PM
