desperate...PLEASE!
Old Nov 10, 2010 | 12:08 PM
  #31
SilverDragon2001's Avatar
Ok so I finally got the tranny dropped after fighting tooth and nail. Look at the clutch assembly thinking..."Oh lord how am I going to get this off?" Tried but all I seem to manage to do is turn the engine. I was trying to get the allen bolts out and when I tried tapping on the wrench black stuff started falling out. Im guessing whats left of my clutch\pressure plate. I am guessing that I am going to need an impact wrench for this one?
Old Nov 10, 2010 | 12:12 PM
  #32
Mike-2ptzero's Avatar
Yes the best way is to use an impact gun. If you dont have one you can use a 12 point socket to hold the front crank bolt keeping the crank from spinning while you take the bolts off and when you put the bolts back in.
Old Nov 12, 2010 | 02:14 AM
  #33
So I got the clutch assembly apart. First thing I noticed was the massive amounts of clutch disk dust falling out. Then when I actully got the thing off first thing I noticed was the stock audi clutch disk and thought to myself "Wow Im pretty sure these are supposed to be a bit thicker than say I dont know two cd's stacked on top of each other IF THAT so yeah disk is toast. Then I looked at the pressure plate...sure enough Mike-2ptzero you were 100% on in the other thread I started before this one... its cracked....in three places. I was like "HOLY ****!!!" So then I started looking at the flywheel....its smooth no ridges or burns. I'm pretty certain I can get by with a resurface which there is a guy I know that works at a shop sometimes that only charges $30. I wish to hell and back that I could just say screw it and get a single mass flywheel but I don't have another $475 to sink into this repair\upgrade. So few questions. I found a stage 2 at APR. Its a DXD (which I have read something about it being CM) for $435. Now. The only mods I have made are the air intake, muffler delete and I am going to see what it sounds like without the resonator (if it sounds ricy then I am definitely putting it back on. Will this be TOO much clutch for me? Im running the stock K03. Second question being is $30 reasonable for a resurface for a flywheel or does this kind of thing normally run like $200 and I shouldn't trust this. That friend....isn't a guy I would trust with the keys to my car because I don't know him THAT well. The website is from the "AUDI LINKS" link ( http://www.goapr.com/products/dxdclutch.php?id=18tlong ) So if someone could please respond. Mike I know you talked to me about it but I want to be clear and not get a clutch that is going to clamp too much for basically my stock-ish car.
Old Nov 12, 2010 | 10:03 AM
  #34
DXD is South Bend's brand name. The SB stage 2 for $435 listed on the APR site is the HD-O which is an organic disk. You can also find it here for the same price but with shipping included in the 48 states.
The HD-O will have a little stiffer pedal then your stock pedal. It is rated for 280tq. If you need a SB clutch that holds a little more power, the HD-TZ and HD-OFE will hold 325 tq.
If you want a stock pedal or slightly softer then stock pedal with high engagement like the stock clutch, you can get a CM FX100 for $425 shipped anywhere in the USA.
Casey1330
Jun 5, 2013 09:02 PM
Kite09
Dec 16, 2011 01:22 AM
barobax
Sep 5, 2011 08:05 PM
badlandz
Apr 27, 2009 03:39 PM
BFlan2001
Oct 22, 2005 09:08 PM
