Diverter Valve.... Work or Not Work
Old Mar 27, 2008 | 01:02 PM
971.8t's Avatar
Default Diverter Valve.... Work or Not Work
Okay, So I am also the one who posted NO BOOST HELP!!!!!!! I am still very in need of some serious help here. I am stilling what for the dealer to call me back. They have replaced the wastegate actuator, they said it was bad, and after that was fixed I am still holding no boost. They checked the turbo and it is spinning and no leaking any oil, they also SAID that they had checked the DV and from what they saw said it was okay, but I think differently. About a week ago I put in a boost gauge, and I am peaking at 1-2 psi, something is majorly wrong here. I physically got underneath the car and checked all of the hoses from and to the turbo and the surrounding parts, evrything was okay, except for the hose from the 1st runner of the intake, a vaccum hose that I teed off for the boost gauge, which was breaded with fabric and brittle. It had a whole in it where it connects to what I believe is the DV. So, I replaced the hose and clamped it nice and tight. That was before I even took the car in. So, I was wondering if that is the correct hose to the DV, if the whole in the line would cause damage to the DV, and an easy way to test if it is working properly.
Please Help I Have Big Plans For This Car
Old Mar 27, 2008 | 01:07 PM
awwdii's Avatar
Default RE: Diverter Valve.... Work or Not Work
I had a hole in my dv and it still boosted. My only guess is to see if the wastegate actuator actually moves when you give it gas. You should see the rod move if not your n75 maybe bad. If it moves very well you could have a hole in the turbo like I did. It was just under the wastegate flap. From what I am reading the dealership does not have a clue and are just shotgun troubleshooting.
Hikerlaird
Jan 8, 2019 11:41 AM
pbbg
Dec 31, 2010 02:14 PM
gwos25
Sep 6, 2009 01:18 PM
mmhyson
Jun 8, 2009 07:19 PM
kraylon
Apr 3, 2006 05:26 PM
