Does the ATP manifold fit the wastegate without a spacer?
Old Dec 4, 2010 | 11:01 AM
xxipsxx's Avatar
Default Does the ATP manifold fit the wastegate without a spacer?
I called their customer support and was told that the manifold pushes out further than the stock mani and that the 38mm wastegate can be mounted on top without a spacer, even thou this is the B5 forum I'll go ahead and say this is for a 1997 audi A4 1.8t Engine Code AEB, Quattro. To me it looks like a super close fit, I've seen other 20v engines on the vortex using spacers and such. Hoping that the longitudinal setup tucks it. Let me know.
Old Dec 4, 2010 | 01:56 PM
Mike-2ptzero's Avatar
Everyone I have seen on the A4 1.8t needed the spacer because that manifold is actually designed for a Transverse 1.8t.
Old Dec 4, 2010 | 02:13 PM
xxipsxx's Avatar
now do I want it to just space the wastegate, of do I want it to space the wastegate and also spin it 90 degrees? I'm going to have to weld the piece myself and I guess take it to go get ceramic coated so I want it to be as perfect as possible the first time I make it. Also do I use 38mm Flanges? And how many degrees approx should the bend be?
Old Dec 5, 2010 | 04:58 PM
xxipsxx's Avatar
anyone have any measurements on that spacer and if it needs to be rotated or not?
Old Dec 6, 2010 | 11:18 AM
No I dont but you can order it directly from ATP
http://www.atpturbo.com/mm5/merchant...Category_Code=
Old Dec 6, 2010 | 12:41 PM
xxipsxx's Avatar
sweet, ty
RaivisGertners
Nov 11, 2018 11:15 AM
connor
Dec 17, 2012 05:54 PM
keefboz
Apr 13, 2009 05:27 PM
4Rings3Liters
Sep 1, 2008 05:48 PM
True_Pinoy
May 5, 2006 06:54 AM
