Does everyones A4 do this? :/
Old Apr 1, 2009 | 01:22 AM
Armenian's Avatar
Default Does everyones A4 do this? :/
Hi, i was wondering if this is something that all A4's do or what is it from. when you start the car and let it run for about a min or so then you hear and feel like it hickup's and like thats when the turbo comes on or something like that but you can deff tell something turns on. does your car do this, or what do you think this is from?
Thanks Guys
01 1.8t A4
Old Apr 1, 2009 | 01:27 AM
bigtm792's Avatar
Member
turbos dont really come on...theyre always on. i have a 2.8 but as its warming up the idol drops. it sounds kind of like a hiccup if thats what your talking about it was never anything i was worried about
Old Apr 1, 2009 | 01:34 AM
ImTheDevil's Avatar
I think what you're hearing is when the secondary air pump turns off - the revs drop at that point as if the AC compressor was turned on and loaded the engine. If that's what you mean, then yeah, all but the 12v V6 cars do that. You only have to worry about it when the car sounds like a vacuum cleaner at startup - that's how you know the $300 SAP is going south on you.
Old Apr 1, 2009 | 01:37 AM
Armenian's Avatar
yeah i know what you mean.. it warms up then as its like at idling at 800 rps or so after 20 secoonds thats when it does it , its not during the time when the idle drops..
no nothing really vacuum cleaner its just like quick drrr and then normall you know
hey and also like when the idle drops low when its warmed up the car has vibration to it not soo much but enough that the arm rest thing vibrates.. is this from like cylinder misfire or something?
Old Apr 1, 2009 | 01:39 AM
pearlescent's Avatar
Yeah the idol will drop once the car is on for a few, couldn't tell yo why though...
Old Apr 1, 2009 | 05:02 PM
punkrocker5817's Avatar
I was under the impression that the worst way to warm a vehicle up is to let it sit for a while. Apparently that does more damage on the engine than anything. The manual even says to not start the car until you're immediately ready to drive, but to keep RPM's low as well.
Old Apr 1, 2009 | 05:41 PM
superdooperme's Avatar
what about the ac/defrost kicking on? could it be that?
Old Apr 1, 2009 | 06:15 PM
redline380's Avatar
Legal Moderator
the reason the manual says that is because audi is wants to be environmentally conscious. just letting it sit there burns gas for no reason in their eyes.
as for letting it warm up, im from minnesota and normally i go out and start the car then go in and take a shower. never had a problem. my reasonign for letting it warm up this long is because of something known as cold seizure (yeah i know its really only for two stroke engines but the principle holds the same) letting the metal inside the engine bay warm up slowly allows the metal to expand at a constant rate. lets say you dont let it warm up and decide to give it hell, the piston will expand more rapidly because it is aluminum and the surronding cylinder is stell which is more dense and more difficult to heat up. what this means is the piston expands and since the cylinder wall isnt expanding as fast, the piston rubs up against the cylinder causing seizure.
now during the summer i dont let it warm up i just keep it under 3000K till i see some sort of water temp and dont give it hell till i see some sort of oil temp.
dbacon89
Aug 8, 2008 06:08 PM
sdsteez
May 28, 2007 12:28 AM
JDCrowe
Jun 5, 2005 02:53 AM
BLarche
May 28, 2005 07:32 AM
