Doing a Boost Leak Test, am I supposed to plug this?
Old May 9, 2011 | 07:10 PM
HeyCesar's Avatar
Question Doing a Boost Leak Test, am I supposed to plug this?
This has probably been asked a few times. I have searched but have been unsuccessful.
I am following this write up:
http://www.a4mods.com/index.php?page...boostleak.html
I've already fabricated a plug for the turbo inlet pipe (why isn't it called a hose?), a plug for the opening in the turbo inlet pipe when you remove the pressure regulator valve.
My question is when you remove the pressure regulator valve are you supposed to plug the other end that it connected to also(PCV return)?
I also found oil in the pressure regulator valve and some oil residue on the hose that connects to the throttle body a while back when I cleaned the TB. Should I be concerned?
Old May 9, 2011 | 08:20 PM
CCA4's Avatar
The TIP is called a pipe and not a hose because it's *supposed* to be rigid. The OEM inlet pipe is admittedly not very rigid, but it was good enough for Audi, apparently.
The oil you saw is common, and one of the downsides to the PCV system. Recirculating the pressurized air from the valve cover/crank case back into the intake allows the oil vapor, condensation, and other gunk to go back into the intake tract, through the turbo, boost hoses, intercooler, and ultimately the throttle body. A good solution to this problem is a catch can, if you'd like more info on that PM me and I can fill ya in.
As for the other end of the pancake valve, you don't need to plug it. Just plug the hole in the tip where you pulled it out of.
Old May 9, 2011 | 10:48 PM
meloman's Avatar
One last thing that I learned this weekend from Dave (dmaxn) is that when you do this you also have to unscrew your oil cap.
josh_easlon
Jun 10, 2009 12:14 AM
black99.5a4
Nov 23, 2008 12:38 AM
oldgearhead
Aug 18, 2008 08:18 AM
erikas3
Feb 12, 2008 08:15 PM
98A498
Dec 19, 2006 12:44 AM
