Double check my PC16 parts...
Old Nov 14, 2010 | 04:37 PM
ericp1.8T's Avatar
Default Double check my PC16 parts...
Just wanna make sure I'm not missing anything so this runs at 100%
What I've got:
99.5 AEB
Borla exhaust
TestPipe
K04
CAI
FMIC
310cc Injectors
Manifold spacer
I'm wondering on the N75 which one is recommended for the pc16, and the FPR I have a 5bar now, Should I do a 3bar or adjustable? If adjustable what should I go with? Not trying to spend a ton on the FPR, so I don't need top of the line.
Old Nov 14, 2010 | 08:06 PM
colony777's Avatar
5bar is what AWEs tune calls for. as far as the n75, stock will work, a J valve n75 would be better, but an adjustable or electronic boost controller is best
Old Nov 14, 2010 | 08:14 PM
Mike-2ptzero's Avatar
The GIAC PC16 file calls for a 3 bar fpr.
Right from the GIACUSA web site.
1999 - 1996 B5 A4 ® w/ K04-15 Turbo Upgrade 1.8T PC16custom 31lb inj. FMIC 3bar FPR M5.9.2 $300USd MSRP
It is the standard tune for the stock injectors that calls for a 5 bar.
1999 B5 A4 ® w/ K04-15 Turbo Upgrade 5Bar FPR 1.8T M5.9.2 $300USd MSRP
The PC16 tune with Bosch 310cc injectors and a 3 bar runs a bit rich. Plenty people running this setup have found that using an adjustable FPR to go just blow 3 bar makes it run better thru the mid range.
If you have the wrong FPR the wrong amount of fuel is being sprayed into the cylinders.
310cc injector at 3 bar = 310cc
310cc injector at 4 bar = 358cc
310cc injector at 5 bar = 400cc
stock 210cc injectors at 5 bar = 271cc
jophish
Apr 13, 2010 12:18 AM
chefro
Jul 16, 2009 09:55 AM
MagicHobo
Nov 12, 2008 05:26 PM
theflash
Oct 14, 2006 11:07 PM
