down and out! (on oil) :( Need some knowledge
Old Sep 29, 2014 | 02:45 PM
dombombBMX's Avatar
Default down and out! (on oil) :( Need some knowledge
My baby a b5 a4 2.8 avant from 1998 is messed up!!!
I was driving to work and there was some road construction. The road dropped like a foot and I was going to fast. Hit the oil pan and scrapped a pretty small hole in it. Oil light came on and I shut the car off drove probably 4 miles dumping all the oil out before the light came on.
Where I'm at now is the car is on jack stands I just jb welded the pan and got some oil and put it in. She started up thankfully but not running right of course! Not hearing any weird noises, no knocking really or tapping. It just misfiring severely as I pulled the codes with vcds lite.
Here are the codes i pulled all seem to be misfiring on same side? Cam Position sensor fault, Knock Sensor fault and misfiring... Maybe someone out there can but this story together?! Need help I don't want to lose this car! Don't know where to start really
VAG-COM Version: Release 409.1-S
Control Module Part Number: 4D0 907 551 AH
Component and/or Version: 2.8L V6/5V MOTR HS D01
Software Coding: 06201
Work Shop Code: WSC 06325
12 Faults Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-00 - -
17927 - Camshaft Position Actuator Curcuit: Bank 1 Malfunction
P1519 - 35-00 -
17746 - CPS, bank 1 open circ./short to B+
P1338 - 35-10 -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 -
P0301 - 35-00 -
16687 -
P0303 - 35-00 -
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-00 - Please Register/Activate
16685 - Shareware Version. To Decode all DTCs
P0301 - 35-00 - Please Register/Activate
16687 - Cylinder 3 Misfire Detected
P0303 - 35-00 - -
16686 - Shareware Version. To Decode all DTCs
P0302 - 35-00 - Please Register/Activate
16717 - Shareware Version. To Decode all DTCs
P0333 - 35-00 - Please Register/Activate
Old Sep 29, 2014 | 05:38 PM
MetalMan's Avatar
Did you clear codes or disconnect the battery prior to starting the engine again?
If not, some of those codes could be residual, in other words they could have been there before the incident.
So if you didn't clear codes already, my suggestion is to 1) clear codes; 2) run the engine again and wait for codes / check-engine-light; 3) report back the new codes.
Assuming it ran out of oil and damage was done before the oil light came on, my guess is that at least the cam journals were starved for oil, causing damage to the cams and/or head.
Old Sep 30, 2014 | 04:03 PM
dombombBMX's Avatar
Yes I did clear the codes and these are the ones that come back.. I did not disconnect the battery yet..
Whats the next step i should take? I should test the cam and knock sensors? Take the valve cover off and start there?
Is there an actuator that is oil fed for timing?
Hobbsy28
B7 Models
Feb 25, 2014 02:27 PM
nemohm
Jan 31, 2008 11:54 AM
nemohm
Jan 23, 2008 03:26 PM
Wilsss
Jun 20, 2006 11:29 AM
awol
Dec 21, 2004 03:28 PM
