Draining the coolant - Drain tube size?
Old Dec 11, 2012 | 07:39 PM
HeyCesar's Avatar
Default Draining the coolant - Drain tube size?
I was wondering if anyone knew what size tube would fit the drain for the coolant off the radiator. I need to change my thermostat once again and the coolant is only about a month old now.
Thanks
Old Dec 11, 2012 | 09:51 PM
DillonT's Avatar
i just put a bucket underneath and drained the valve.
Old Dec 12, 2012 | 12:20 PM
mtroxel's Avatar
It's cleaner if you use a hose that fits right over that little outlet there. I do it all the time. Don't have that hose around that I used though. I think the ID of the hose is about 5/8 inch...but I'm really not sure.
Old Dec 13, 2012 | 08:04 PM
HeyCesar's Avatar
Thanks, I'll try that.
Old Dec 14, 2012 | 05:33 AM
DOC_DEPALMA's Avatar
Ditto for the bucket, if not you could just use a funnel with a hose on that, into an empty container like a coolant container or whatever
Old Feb 3, 2013 | 12:38 AM
waveblaster200's Avatar
Hey I gotta drain my coolant, did you guys figure out what size hose to fit the outlet? Is it 5/8s. Normally I just pulled the blue sensor down there. But this looks less messy. Thanks!
Old Feb 3, 2013 | 08:32 AM
mtroxel's Avatar
Don't know. It's not 5/6 though. I'd say the inside diameter is more like 3/8, but I'm not sure. I just know I have a hose in my garage that fits over that nicely.
oldmots
Sep 9, 2010 11:20 AM
errol619sd
Jul 31, 2008 10:37 AM
B5luver
Apr 10, 2007 10:42 PM
Blindmonkee
Feb 1, 2007 01:45 AM
mdunn
May 30, 2006 08:29 PM
